dynaflowmoe
Post by dynaflowmoe on Sept 6, 2018 7:59:04 GMT -8
I am currently restoring (actually completely rebuilding) a 1964 Shasta SCS. I am to the point of re-installing the skin and replacing some as well with new metal. My dilemma is with the Z stripe. I am replacing the skin on the curbside and am not sure how to duplicate the stripe to match the old metal which is of course unpainted (the stripe that is). I purchased the new metal from Hemet RV Siding and took a scrap to see how I could simulate the stripe by removing the white paint. I used Jasco's best paint stripper and it wouldn't even touch the paint! Is my only option to use some chrome tape on the new metal and settle for that? I am curious how others have dealt with this as I am certainly not the first to face this problem. Thanks in advance for any help and this is a GREAT website by the way.
Post by nccamper on Sept 6, 2018 8:12:24 GMT -8
This may help. Fast forward to the Z.
dynaflowmoe
Post by dynaflowmoe on Sept 6, 2018 9:08:21 GMT -8
Thanks, that's a great tutorial however as I read it I can't see where he had a problem removing the paint on the new panels for the bare metal stripe. I cannot get the paint stripper to even soften the paint on the new metal let alone remove it. I left it on for 15 minutes and when I attempted to scrape off the paint, the stripper wiped off like I had brushed water on it. It did not react with the paint whatsoever. I guess I will try it again and leave it on a little longer. The temperature was about 80F outside and it was overcast so I know the sun didn't dry up the stripper.
charliemyers
Post by charliemyers on Sept 6, 2018 10:02:32 GMT -8
nccamper's post says that he buffed it off with 0000 steel wool.
dragonwagons
Polish
Post by dragonwagons on Sept 6, 2018 14:42:57 GMT -8
Google aircraft paint remover. Try that, it should work.
dynaflowmoe
Post by dynaflowmoe on Sept 6, 2018 16:17:43 GMT -8
Thank you both for the suggestions, I will try them.
Post by nccamper on Sept 6, 2018 17:31:24 GMT -8
I left it on for 15 minutes and when I attempted to scrape off the paint, the stripper wiped off like I had brushed water on it. Jasco semi paste worked for me with 0000 steal wool. I may have started with 000, but it didn't come off easy.
Hemet may have changed suppliers.
