kaffi311
1963 Shasta 16 SC
Post by kaffi311 on Aug 17, 2018 15:17:17 GMT -8
So I have the 12v pump connected to water tank- all under street side bench. I have PEX running from pump across front of floor into curbside bench. 90 degree turn - then PEX runs under kitchen cabs into the area under sink. From there- how do I connect? Do I transition from pex to flexible/braided pipe up to sink faucet? I just need to be clearer on the connection from there. Hope this is understandable! Thanks a ton! Pictures would be so appreciated if you have one!!
kaffi311
1963 Shasta 16 SC
Post by kaffi311 on Aug 18, 2018 12:16:33 GMT -8
anyone? lol
Post by vikx on Aug 18, 2018 20:22:15 GMT -8
Use flex connections from the pex to the sink faucet. I use 1/2 IP x 1/2 IP, so you'll need a 1/2 IP male fitting at the pex end. Also, it's MUCH easier to connect the faucet before everything is built around it. Unless you're a pretzel, that is...
