skelee
Post by skelee on Aug 15, 2018 13:13:56 GMT -8
I need to replace the bearings, seals, and D washers. Front bearing L44649 Rear bearing LM48548
The only number I can make out on the seal is 205015. This number does not produce any results on a search. I was hoping there was a kit that came with the everything including the race and caps.
kudzu
Post by kudzu on Aug 15, 2018 16:43:36 GMT -8
skelee
Post by skelee on Aug 16, 2018 2:13:41 GMT -8
The front and rear bearings are different and their is only one rear seal
Post by nccamper on Aug 16, 2018 3:36:48 GMT -8
I took the bearing and seal into CarQuest and they found it. Oddly, the seal they had in stock the bearing needed ordered. I bought an extra set as a back-up.
