brian1313
Post by brian1313 on Aug 3, 2018 5:27:09 GMT -8
So I know there are tons of stuff on here about painting and I saw the $200 paint job post which was really good. I cannot spray as I do not have the resources nor the space to do so. I plan on rolling. I have seen a few people post about the ace rust stop paint however it says not for automobiles so I was not sure if that would apply to campers. The link is below. has anyone used this? If so what are your thoughts? Are there any other paints that you would recommend that can be bought from Ace or Lowes or HD (places like that) www.acehardware.com/departments/paint-and-supplies/specialty-paints/rust-prevention/16753
Post by danrhodes on Aug 3, 2018 5:33:46 GMT -8
Search the $50 paint job on Google. Standard rustoleum enamel can be thinned and rolled to a very nice finish. I sprayed valspar tractor paint but I also brushed it on my propane tank and it leveled out nicely
brian1313
Post by brian1313 on Aug 3, 2018 5:50:32 GMT -8
I saw the rustoeulem the only problem is you cant tint it and the ace stuff offers a little more color vairety than the restoeleum
Post by mel on Aug 3, 2018 7:05:04 GMT -8
A few people have used ace rust stop on here. search nccampers $200 paint job
oakback
Post by oakback on Aug 3, 2018 7:27:57 GMT -8
kamhawk
1975 Scotty Serro
Post by kamhawk on Aug 3, 2018 8:30:49 GMT -8
On the topic.....Has anyone tried the tractor, truck and implement paint from Tractor Supply? Also, does anyone know if it can be tinted? A gentleman seeing me purchase it claimed it was good paint and said he worked at a body shop and didn't know why it couldn't be tinted....Thoughts IMG_20180803_102623818_LL by KamHawk, on Flickr IMG_20180803_102648209_LL by KamHawk, on Flickr
brian1313
Post by brian1313 on Aug 3, 2018 9:47:59 GMT -8
I found some more rusteloum options at HD and am going to give it a try.
Alaska Shasta
1964 Shasta
Post by Alaska Shasta on Aug 3, 2018 10:07:02 GMT -8
On the topic.....Has anyone tried the tractor, truck and implement paint from Tractor Supply? Also, does anyone know if it can be tinted? A gentleman seeing me purchase it claimed it was good paint and said he worked at a body shop and didn't know why it couldn't be tinted....Thoughts I work in a body shop and have been around automotive paint since 1979. You can tint this with only the same kind of chemical makeup paint. If you have access to the other colors made by this company, you can tint with them as long as it is the same series of paint. I really like the fact that it has a hardener. This really ups the quality of paint. DO NOT OVER CATALYZE! Use the ratio exactly as stated. If you over catalyze, it will not harden properly and remain soft. IMG_20180803_102623818_LL by KamHawk, on Flickr IMG_20180803_102648209_LL by KamHawk, on Flickr
kamhawk
1975 Scotty Serro
Post by kamhawk on Aug 3, 2018 10:55:46 GMT -8
So in theory, if I take Ford blue and John Deere green (from this brand), I can mix with the white to make the Scotty blue I'm looking for
Alaska Shasta
1964 Shasta
Post by Alaska Shasta on Aug 3, 2018 11:39:21 GMT -8
So in theory, if I take Ford blue and John Deere green (from this brand), I can mix with the white to make the Scotty blue I'm looking for Absolutely!
kamhawk
1975 Scotty Serro
Post by kamhawk on Aug 3, 2018 12:33:18 GMT -8
Thanks for your input
