aslmx
Post by aslmx on Jul 30, 2018 19:05:07 GMT -8
not sure of the model but it’s a super something. Does it have a serial number on the tongue? We’re going to need pics of the inside and that ac looks HEAVY on that light built roof.
jcauley
Shasta
Post by jcauley on Jul 30, 2018 19:10:42 GMT -8
going to have to grind years of paint off tongue to get serial number, the interior has been completely remodeled, I put extra bracing in the celing to accept AC
Post by nccamper on Jul 31, 2018 4:19:15 GMT -8
Post a request to info in this thread.
Our resident expert should be able to help but a vin number will give you more detailed info.
Post by Ten on Jul 31, 2018 18:54:20 GMT -8
First, there seems to be an emblem mounted beneath the big "Shasta" emblem. Shasta did not put model names on the trailers, like car manufacturers did, until the very late 60's and early 70's. I can't make out what it says in the photo, but if it is even partially there, it would be a huge clue.
Second, do NOT take a grinder to the paint to search for a VIN number, a wire cup brush in a drill or Dremel tool work well for removing paint and revealing the VIN. The numbers are stamped into the metal on the tongue and can be easily obliterated with anything too aggressive.
I'm going to go way out on a limb and take a wild-assed guess. It doesn't appear it is a Starflyte, Ultra, or Super, all of which had some version that included the trunk back. I am thinking that it is the 19' Deluxe, judging by the window layout and the apparent length. It is only a guess though. I'm still looking for definitive proof for you. If you have any photos of the interior layout before the remodel that will help too.
Post by mobiltec on Aug 3, 2018 8:13:06 GMT -8
going to have to grind years of paint off tongue to get serial number, the interior has been completely remodeled, I put extra bracing in the celing to accept AC You must also beef up the walls that support the roof if you want to hold a roof top AC on the trailer. Just beefing up the roof is not sufficient.
jcauley
Shasta
Post by jcauley on Aug 3, 2018 11:33:31 GMT -8
It has been there over 10 years and about 3000 miles
Post by mobiltec on Aug 3, 2018 14:02:27 GMT -8
Obviously you don't need any advice from the likes of me.
