barefootonthefarm
'64 Yellowstone
Post by barefootonthefarm on Jul 28, 2018 11:18:09 GMT -8
Were Shasta’s, specifically 63 Astrodome J rail originalltbpainted or left aluminum? Mine looks like it was originally painted, but not sure if that’s right.
dragonwagons
Polish
Post by dragonwagons on Jul 28, 2018 12:38:46 GMT -8
No idea since mine was covered in, what I think was house paint.
Post by vikx on Jul 28, 2018 21:52:07 GMT -8
My 57 had painted trim but it will be mill finish now. Painting J rail is difficult to do and it's hard to get enough paint on every surface. I like the plain trim setting off the painted trailer.
Post by nccamper on Jul 29, 2018 4:38:58 GMT -8
Adding to vikx's comment above, once painted jrail can't be removed without destroying the paint job. And paint putty can crack (slightly) when exposed to very cold temps and high temps can cause oozing.
I've painted the rail and polished and both looked great. Both ways need the old paint removed which is a lot of work.
I'm not sure if the jrail was always painted from the Factory.
Post by Ten on Jul 29, 2018 5:15:58 GMT -8
My '64 Airflyte has original paint on the j-rails, in answer to your question. I have taken some off using a fairly coarse steel wool, but must warn of the impending carpal tunnel that follows. I am planning to someday polish it all and leave it unpainted in it's next lifetime.
acameron
Post by acameron on Jul 30, 2018 6:54:07 GMT -8
My 59 Mercury looked painted and we painted it when we painted the camper. If I had to do it again I think I would either polish it or paint it before installing. I like the sharp shiny lines on some of the other folks campers. I used a spray gun so painting it wasnt to difficult.
